Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent 22R2 on HPC slows down by time Reply To: Fluent 22R2 on HPC slows down by time
For a VAWT you shouldn't need to remesh as the motion is typically circular - ie it spins. You can usually use sliding mesh, possibly with embedded zones, and then either set the speed directly or via the moving mesh UDF.Â
