Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Help for qINTERCONNECT › Reply To: Help for qINTERCONNECT
I opened the NLS_ideal.py script using the 'Open Script' option and ran the code directly. It worked without any issues, so I am unsure what needs to be changed. Could you please clarify what the problem might be with this approach?
My main issue is this: how I can run the code in Spyder I mean (via external Python environment) not only from Interconncet bundled script ?
Additionally, I have another question. May I ask how I can view the circuit in a graphical interface? I noticed in the provided Link that a circuit is generated. However, after running all three codes in INTERCONNECT, I do not see a similar circuit. Could you please guide me on how to achieve this?
