Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › PLT file error › Reply To: PLT file error
November 15, 2024 at 11:31 am
Please have a look at using AqwaReader to retrieve the cable tension results. This data will exist in the Aqwa solver results file, but they may be a bug in Aqwa Workbench that prevents these specific results from being read into the editor. AqwaReader should certainly be able to access the data you need.
Mike
