Ansys Learning Forum Forums Discuss Simulation Electronics core and winding losses in 2d/3d Reply To: core and winding losses in 2d/3d
Timotheos Fetsis
Hello, when setting up your simulation, you should ensure that the excitation method aligns with the physical behavior you're trying to model. If you're experiencing significantly different losses with different excitation methods, it may be beneficial to review the physical setup of your model and ensure that the excitation method you're using is representative of the actual transformer operation.
