Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Meshing error › Reply To: Meshing error
November 12, 2024 at 2:14 am
muhammadagussriharto
Can you duplicate the model and generate a mesh using the default settings without changing anything, does that work ? I have do that but still have same resultÂ
Can you share a snipshot of the geometry that you are using to generate the mesh ? yes , I share the geometry to you , look at the below . the geometry is hollow beam with thickness overall 10 mm and arranged like that .Â
Does it only have shell surfaces after you used mid surfacing tool? yes , exactly.Â
Please give me a help like advice to make meshing into succesful
