Ansys Learning Forum Forums Discuss Simulation Fluids Expression does not evaluate to a single value Reply To: Expression does not evaluate to a single value
Federico Alzamora Previtali
This expression is a function of Static Temperature, so indeed it does not evaluate to a single value and you will not get an output from the Expression window. It does not mean however that this is a problem. Try initializing your solution and do a Contour plot for this expression to check that it evaluates to the right range.
