Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Phase in frequency domain analysis in AQWA › Reply To: Phase in frequency domain analysis in AQWA
Shuangxing Du
Once you have run the current setup, the current results will overwrite the previous ones in your project folder.  However, your previous results are temporarily stored in the backup folder. When you exit Workbench, the window below will pop-up, and if you clcik on "No" to not save your current project, the previous setup will be restored into your project folder.
