Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to define one-input two-output RLGC model for circuit transient simulation › Reply To: How to define one-input two-output RLGC model for circuit transient simulation
ssano
Thank you for your inquiry.
As you pointed out, it is not possible to define two Sinks on one net.
This is because the current path cannot be uniquely determined.
As you understand, we define two Sources and one Sink to output the equivalent circuit.
When excluding Capacitance, if only Resistance and Inductance are in the circuit, the analysis results should be the same regardless of which point is set as the Sink.
