Ansys Learning Forum Forums Discuss Simulation LS Dyna *INITIAL_VELOCITY_GENERATION_START_TIME Reply To: *INITIAL_VELOCITY_GENERATION_START_TIME
Ram Gopisetti
It appears the only issue arises from the usage of *INITIAL_VELOCITY_GENERATION_START_TIME in conjunction with *INITIAL_VELOCITY_RIGID_BODY.
*INITIAL_VELOCITY_RIGID_BODY is incompatible with *INITIAL_VELOCITY_GENERATION_START_TIME. Instead, you should use *INITIAL_VELOCITY_GENERATION with PHASE=1, scoped to the rigid body. This allows you to define the velocity generation, and then apply *INITIAL_VELOCITY_GENERATION_START_TIME to introduce a delay before the velocity is activated.
For additional details, please refer to the *INITIAL_VELOCITY_GENERATION_START_TIME section in the LS-DYNA Manual, Volume 1.
Cheers, Ram
