Ansys Learning Forum Forums Discuss Simulation General Mechanical External data / Thermo-Structural analysis / Coupled field transient Reply To: External data / Thermo-Structural analysis / Coupled field transient
paaulocz
Hi Erik,
Thank you very much for the information. I will look into the possibility of changing the software version.
Regarding the other question, since pressure is available in the version I'm using, I tried applying it from the external data, but I encountered the message “The data in the worksheet is invalid. Please correct before proceeding to import.” Have you come across an issue like this before?
In the external data, I have x-coordinate, pressure, and heat flux for various time intervals. As mentioned, pressure is available, but heat flux is not. I tried applying pressure, but the error above occurred.
