Ansys Learning Forum Forums Discuss Simulation General Mechanical Why DOF is looks like 3 DOF?(Modal Analysis with Linear) Reply To: Why DOF is looks like 3 DOF?(Modal Analysis with Linear)
Erik Kostson
Hi
You are using a 3D solid body, that will be meshed with 3D elemets (solid185) that have 3 dof (at each node), and not 6.
See the help manual for more info on solid185 elements that are used when you set mesh to linear in modal analysis.
All the best
Erik
