Ansys Learning Forum Forums Discuss Simulation Fluids ANSYS AQWA – Simple Floating Sphere – Errors Reply To: ANSYS AQWA – Simple Floating Sphere – Errors
as4934
It is just a sphere that is supposed to be floating on water. I have attached an image. I was under the impression that I should use an internal lid if my structure breaks the surface of the water.
Thank you for your help.
