Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › unable to run the job › Reply To: unable to run the job
November 1, 2024 at 5:21 pm
Hello Rajesh,
You can pick the license type that you want to use. LSTC or Ansys. Note that we no longer issue node locked licenses.
You will find more information about LS-RUN in the following video:
https://www.youtube.com/watch?v=ymkTJCefm30
If you set LS-RUN to use the Ansys license, it should set the LSTC_LICENSE=ansys environment variable automatically.Â
You have to make sure you set the following 2 environment variables properly on the client machine:
ANSYSLMD_LICENSE_FILE=1055@hostname_Ansys_License_Server
LSTC_LICENSE=ansys
Let me know how it goes.
Reno.
