Ansys Learning Forum › Forums › Discuss Simulation › Optics › Metalens in THz range has Zero transmission › Reply To: Metalens in THz range has Zero transmission
Niki Papachristou
Hi David,
Thank you for reaching out to us! I believe the online example is created for visible range. I suspect that if you want to go to THz range you will need to change the dimensions of the unit cell as well as the refractive index/material.
I hope that was helpful, let me know if you need any further assistance.
Kind Regards,
Niki
