Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Ball movement under water flow › Reply To: Ball movement under water flow
October 28, 2024 at 12:29 pm
When you define your 6DOF properties, you can select Translational 1DOF. You then need to define the direction of motion (whatever the horizontal direction is in your screenshots)
