Ansys Learning Forum Forums Discuss Simulation Fluids Ball movement under water flow Reply To: Ball movement under water flow
Federico
Refining the mesh will further constrain your allowable time step size.
Can you show the mesh after the negative volume mesh error?
Also, I would suggest using the Unified Remeshing method instead of Methods Based, which requires more tuning.
