Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Workbench contents blurry on a 4k monitor › Reply To: Workbench contents blurry on a 4k monitor
Rajeshwari Jadhav
Hi Venki,
Change the display resolution of affected system to check if that helps.
Goto Start menu> Display settings> Scale and Layout. Try to change these options and check if any of it works for workbench.
if above method doesn't work try the below options too.
Can you set below environment variable under system variable
MECH_BROWSER_USE_AUTO_SCALING="1"
If that doesn't work and makes the scripting view too small. Please try updating the DPI settings for the Mechanical process, as suggested here for Workbench process.
General Workbench Issues (ansys.com)
