Ansys Learning Forum Forums Installation and Licensing Ansys Products No conductors were found on port ‘1’ Reply To: No conductors were found on port ‘1’
Aymen Mzoughi
These errors can be spotted before the simulation by running the validation checker (menu HFSS > Validation Check). The ports need te be defined properly.
Depending on which PCB tool you are using, it is recommended to use the Ansys EDB format for import if possible. Otherwise try IPC2581
Finally, you can manually add the via in HFSS 3D Layout:
