Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problems for creating a .jou journal file to run the simulation on a cluster › Reply To: Problems for creating a .jou journal file to run the simulation on a cluster
Yes.... I'd set the model up, initialise and run 1-2 iterations locally to make sure everything is behaving. You then need a TUI (console) journal to read case & data then run some iterations, finally to write case & data so you can get the results back. Do NOT record a macro based GUI journal as they never work well on remote systems, and rarely work locally!
