Kinjal
#include “udf.h”
DEFINE_PROFILE(dynamic_heat_flux, thread, position)
    int n = N_ITER;         // Get the current iteration number
    real q0 = 0.5e6;        // Initial heat flux (W/m^2)
    real q;                 // Heat flux at the current iteration
    real chf = 3e6;      // CHF value (W/m^2)
    // Determine the heat flux based on the iteration number
    if (n <= 500)
        q = q0;
    else
        int i;
        q = q0;
        for (i = 500; i <= n; i += 300)
            // Check if q approaches 75% of chf
            if (q >= 0.75 * chf)
                q += 0.1e6; // Increment by an additional 10% step
            else
                q += 0.5e6; // Increment the heat flux by 0.5e6
    // Print the heat flux value after every 300 iterations
    if (n % 300 == 0)
        Message(“Iteration %d: Heat Flux = %g W/m^2\n”, n, q);
    face_t f;
    begin_f_loop(f, thread)
        F_PROFILE(f, thread, position) = q; // Apply the heat flux
    end_f_loop(f, thread)
this is how heat flux is applied
