Ansys Learning Forum › Forums › Discuss Simulation › Electronics › ANSYS Maxwell solver simulation progress › Reply To: ANSYS Maxwell solver simulation progress
GLUO
Magnetostatic uses adaptive solver. Maxwell creat an initial mesh first, then add nodes and mesh to the initial mesh at each pass according to convergence condition. In your parametric, it ask you which analysis setup is used for parametric. The convergence criteria used in this setup is applied to the parametric. In your solution data - convergence tab, you can choose design variations to view convergence report for different variations.
GL
