Ansys Learning Forum Forums Discuss Simulation Electronics Excitation to model the litz wire Reply To: Excitation to model the litz wire
GLUO
In material properties, there is a "litz wire" option for composition. You can directly use it and model the whole coil using a big circle.
If you would like to model each strand with in one coil, you can assign coil terminals on every one of them.
GL
