mohan.urs
Hey,
Can you try generating a mesh with default settings and check whether its able to generate a mesh.
The mesh generation is failing due to the errors and not the warning you have mentioned. The mesh quality seems to be bad so solver does not continue to generate a mesh. Try changing the settings you have defined to generate a mesh. If you want to ignore that and continue, try turning the check mesh quality in mesh settings to NO. But the results might not be reliable due to poor quality mesh after turning it to NO.
Let me know how it works out.
Thanks
