Ansys Learning Forum Forums Discuss Simulation Fluids Problem in Geometry and motion frame between two geomentries Reply To: Problem in Geometry and motion frame between two geomentries
vamsinaik_p210043ce
Thank you for your response.
I should refrain from applying motion to the beam, as my goal is to utilize the cube to move the beam and to analyze the forces generated on both the beam and the particles. Is there a method to prevent the cube from penetrating the beam?
