Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Negative eroding contact energy in impact testing › Reply To: Negative eroding contact energy in impact testing
Reno Genest
It is possible that the negative eroded internal energy is caused by negative volume error. If you get negative volume or out-of-range forces or velocities error messages without a failure criteria, this indicates some degree of instabilities in your model. I would try to fix the negative volume and instability problem first and then try to activate element erosion again. Here are some tips to combat instability and negative volume errors:
  • Make sure you have a good quality mesh. If the element quality is bad, you are more likely to have elements with high distortion and negative volume.
  • Reduce the time safety factor (TSSFAC on *CONTROL_TIMESTEP) from 0.9 to 0.66. This can be effective especially if the impact is very fast.
  • Increase the d3plot output frequency and animate the results to see what is happening and what triggers the instability.
Also, I would try to remove the *CONTACT_AUTOMATIC_SINGLE_SURFACE for now. Having redundant contacts is not recommended.
You will find more information on negative volume and instabilities here:
https://ftp.lstc.com/anonymous/outgoing/support/FAQ/negative_volume_in_brick_element.tips
https://ftp.lstc.com/anonymous/outgoing/support/FAQ/instability.tips
https://lsdyna.ansys.com/have-you-any-tips-on-how-to-to-combat-instability/
https://lsdyna.ansys.com/negative-volumes-in-brick-elements/
Let me know how it goes.
Reno.
