Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Simulation stopped to work after switching the computer › Reply To: Simulation stopped to work after switching the computer
mohan.urs
Hey,
Did you use the same Ansys versions while solving both the cases ?
You said that there were some warnings while solving can you post the screenshot of those warnings.
Do check out this course and set your contact up properly. Prevent Rigid Body Motion in Contact - Innovation Space (ansys.com)
Since you are performing a transient analysis do you have proper settings for timesteps or is it using program controlled. If its program controlled i would suggest providing sufficiently small timesteps to see what is causing the issue.
If you have a few converged steps, check the deformation plots and idenity the cause through that.
Let me know how it works out.
Thanks.
