Ansys Learning Forum Forums Discuss Simulation Fluids Problem in Geometry and motion frame between two geomentries Reply To: Problem in Geometry and motion frame between two geomentries
I'm not sure Rocky has built in collision detection for geometry. Can you simply set the beam to move at the same rate as the cube?Â
