Ansys Learning Forum Forums Discuss Simulation General Mechanical Spreader Lifting Beam Reply To: Spreader Lifting Beam
mohan.urs
Hey,
If you are still unsure about its application and modification using the coordinate system. Try setting it up for a simple symmetric model and verify its behaviour.
  • And I didn't understand what you meant by task, I'm assuming that you meant that you didn't define it in engineering data. In that case the selection information in mechanical will show the volume of all the bodies selected, you can use that to manually find out the weight of the bodies.
Thanks
