Ansys Learning Forum Forums Discuss Simulation LS Dyna *BEAM_SOURCE Reply To: *BEAM_SOURCE
Reno Genest
Hello Oliver,
You should be able to visualize the cross section of *ELEMENT_BEAM_SOURCE if you read the d3plot and the input.k file in LS-PrePost. The beam elements that are pulled out should be in the same part as the source element and inherit the same *SECTION_BEAM.
Here is an example if I read only the d3plot in LS-PrePost:
And if I read the d3plot and the input.k file in LS-PrePost:
Let me know if this works for you or not.
Reno.
