Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to customize pulse waveform and injection site in microstrip array › Reply To: How to customize pulse waveform and injection site in microstrip array
dushyant.marathe
Hi Eli Brunner,
I would suggest you to create ports for exctitation point in HFSS. You can also creates ports at other ends of lines for terminations can be Lumped Ports.
The solved HFSS model can be taken as component in to Ansys Circuit where in component library you can look for a suitable source. You can use a push excitation feature from Ansys Circuit to fed back circuit excitation in to HFSS model to visualize fields etc.
For more detailed guidance on co-simulation using HFSS Circuit and HFSS MCAD, you can refer to the provided resources which explain the process of inserting ports, creating voltage sources, and analyzing the circuit https://www.youtube.com/embed/wa6HlTj1ecA?feature=oembed
Please note that you may need to consult the Ansys Circuit documentation or seek additional resources that specifically address Gaussian signal pulse creation in Circuit or HFSS.
Thanks,
