Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Cyclone (Stairmand) simulation using RSM › Reply To: Cyclone (Stairmand) simulation using RSM
October 10, 2024 at 3:20 pm
Thank you. I'm not exactly sure what you mean, but I do have some idea. I'm also monitoring total pressure at the inlet and top outlet to see whether they are able to converge. This seems to be happening. I understand that the flow in the cyclone is implicitly unsteady. But still, the continuity residuals should be able to go at least under 1e-3, right?
To add on the previous post, this is my contour of the tangential velocity:
Thank you for the tip regarding radial pressure distribution.
