Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Mesh generation leads to errors › Reply To: Mesh generation leads to errors
mohan.urs
Hey,
Can you check the gemotry once in spaceclaim. (https://ansyshelp.ansys.com/public/////Views/Secured/corp/v242/en/spaceclaim/Discovery/user_manual/checkgeometry.html)
Try to generate a default mesh without changing any mesh setting and see if it puts out any error. If any error comes up right click on it and see what the problematic area is (fix it in spaceclaim after that)
Share some mesh setup info if the errors still don't go away. So that others can help you.
Thanks
