Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Intersected faces found for matching interface periodic-walls › Reply To: Non-Intersected faces found for matching interface periodic-walls
October 8, 2024 at 4:29 pm
thank you that worked! changing the offset to 90deg fixed the issue. lastly- how can i check the periodic BCs are being enforced correctly? there's a way for me to "mirror" the blocks but would that be showing the mirrored BCs or projecting the flow field results as a mirror image?
