Ansys Learning Forum Forums Discuss Simulation Fluids Non-Intersected faces found for matching interface periodic-walls Reply To: Non-Intersected faces found for matching interface periodic-walls
zoelle.wong
For the solver, i set it to be an auto conformal, origin at (0,0,0),  axis of rotation (1,0,0,), and the auto-offset was calculated as -5deg. I think the offset might be too large; I did manuall decrease the offset at different angles less than 5deg but then the periodic BC wasn't built
