Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Non-Intersected faces found for matching interface periodic-walls › Reply To: Non-Intersected faces found for matching interface periodic-walls
October 8, 2024 at 2:49 pm
zoelle.wong
ah i see- the angle between the two faces are 90deg. should i change the mesh such that the angle between the two faces is 180deg?
