Ansys Learning Forum Forums Discuss Simulation Fluids Non-Intersected faces found for matching interface periodic-walls Reply To: Non-Intersected faces found for matching interface periodic-walls
5 degrees? Can you confirm as the image looks a little larger than that.Â
