Ansys Learning Forum Forums Discuss Simulation General Mechanical Part transformation in Parameter set Reply To: Part transformation in Parameter set
mohan.urs
Hey,
Part transformations are possible from parameter set, even if its a LS- DYNA simulation.
  1. Check if you have linear order elements only in the model.
  2. Try to retain the solution for all design points.
  3. Check whether the transformations you intend to do is actually being applied for all design points.
  4. Try solving the model for one trasnformation alone (without parameterizing) and check if the model completes the run.
  5. Try to review the solve.out file even if the simulation failed, It should point out to some error for why the simulation failed.
If it still doesn't work, try to share some insights on the model setup and how you are transforming the parts in the mechanical.
