Ansys Learning Forum Forums Discuss Simulation Preprocessing Mesh of a packed bed Reply To: Mesh of a packed bed
mohan.urs
Hey,
Look into options like Transition, Growth rate, Span angle settings. These work with adaptive sizing. I'll include the help links for these.
https://ansyshelp.ansys.com/Views/Secured/corp/v241/en/wb_msh/msh_sf_adaptive.html
https://ansyshelp.ansys.com/Views/Secured/corp/v241/en/wb_msh/msh_Growth_Rate_SF.html
https://ansyshelp.ansys.com/Views/Secured/corp/v241/en/wb_msh/msh_Trans.html
https://ansyshelp.ansys.com/Views/Secured/corp/v241/en/wb_msh/msh_Span_Ang_Cent.html
You can also set biasing to edges along which you can control the bias of element sizes, you can check out the link below for more help on this.
https://ansyshelp.ansys.com/Views/Secured/corp/v241/en/wb_msh/wb_msh_q1d_zhp_1w.html#msh_Bias_Type_Factor
