Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Time averaged enthalpy at multiple points › Reply To: Time averaged enthalpy at multiple points
Prashanth
Hi, can you confirm the sampled dataset or sampling time has a physical converged solution. You can also write the data to a output file and check if the reported numbers are physical.
