Ansys Learning Forum Forums Installation and Licensing Ansys Products In CFD Post, I can not see mesh regions! 2024 R2 Reply To: In CFD Post, I can not see mesh regions! 2024 R2
V.P
Hi Shin7,
The mesh regions should be visible as before. If they're not showing, it might be a graphics error. Here’s a fix you can try:
  1. Go to C:\Users\username\ on your computer.
  2. Locate the folder named .cfx.
  3. Rename this folder to .cfx_backup.
  4. Open CFD-Post 2024 R2 again and check if the issue is resolved.
After doing this, a new .cfx folder will be created in C:\Users\username\. If everything works correctly, you can delete the .cfx_backup folder if you want.
