Ansys Learning Forum Forums Discuss Simulation General Mechanical The transverse shear stiffness matrix of Shell 281 element Reply To: The transverse shear stiffness matrix of Shell 281 element
erik.kostson
Hi
Assuming you use user integrated shell formulation (so using SSPX commands)
Define SSPE (there might be some simple expressions that approximate it, say ~ constant*G*thick.) as it is needed for membrane + bending analysis (if it was only membrane option, then SSPE is not needed - see help manual).
Perhaps other forum members have some further feedback.
All the best
Erik
