Ansys Learning Forum Forums Discuss Simulation LS Dyna How to import fiber orientation analyzed in Moldflow 21 into LS-DYNA? Reply To: How to import fiber orientation analyzed in Moldflow 21 into LS-DYNA?
zxhurs
Hello Reno,
Thank you very much for your suggestion. Apologies, I may not have been detailed enough in my explanation. I found a window related to Moldflow in Le Prepost 4.7, as shown in the image below. I’m trying to use this window to map data, including fiber tensor data from Moldflow, into LS-DYNA. I’m confused about how to use this window because there isn’t a specific guide, especially for the “Pick Segments” option. I selected two mutually perpendicular surfaces, but the results displayed are quite confusing. Do you know what the issue might be? Or what the specific steps are?
I really appreciate your advice. I personally prefer trying to run it in LS-PrePost first. If it doesn’t work, I’ll try doing it in Ansys Workbench. Your suggestion might lead to a better outcome, but I still want to give this a try, as there’s already an existing window for Moldflow to LS-DYNA conversion.
Thanks!
