Ansys Learning Forum Forums Installation and Licensing Ansys Products Update failed for model component in static structural Reply To: Update failed for model component in static structural
Armin
Hi Medha,
The error message you're getting could be related to issues with the model setup or the state of the geometries within your project. Could you describe more about your model?
Also, check the following knowledge material that indicates that this error might be caused by the CAD modeling tool: SpaceClaim import fails with "Update failed for the Model component..." - Ansys Knowledge
