Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Overlapping of Domains during Appending of case files › Reply To: Overlapping of Domains during Appending of case files
Petros
It seems like the interface pair is not matching exactly one another, probably due to incorrect location of the domains. As suggested above it would be better to create the whole domain at once and split it before and after the rotor so then you have your 3 domains which you can import in one go.
