Ansys Learning Forum Forums Installation and Licensing Ansys Products Problems with CDB file from MAPDL to Workbench and Pressure Mapping Reply To: Problems with CDB file from MAPDL to Workbench and Pressure Mapping
ML
Thank you very much for your reply, it is very helpful!
I tested my case on a Windows machine and I can correctly connect the External Model to both Engineering Data and Model cells, so I assume that the problem was specific to Ansys on Linux.
If I export the CAD geometry to remesh it in Ansys Mechanical, would there be a way to quickly import the composite plies? Could I use MAPDL Commands in Ansys Mechanical to define the plies? As there are so many plies to define, it would be unfeasible to do it manually.
Thank you again for your help!
