Ansys Learning Forum Forums Installation and Licensing Ansys Products Layout of the latest ANSYS version (2023/R2) Reply To: Layout of the latest ANSYS version (2023/R2)
Rajeshwari Jadhav
The client machine should point to server machine, launch Ansys Licensing Settings as an admin add port no. and servername> test (green check mark should appear)> save> click on feature in use tab, verify if all increments are visible.
If you don't have admin access then launch environment variable and add variable
variable name: ANSYSLMD_LICENSE_FILE
variable value: portno.@servername
Note: port no. should be replace by your actual port no. (by default it's 1055), servername should be replaced by servername of server machine(Ansys License Manager).
Share screenshot if you face any issues.
