Ansys Learning Forum Forums Discuss Simulation Fluids Overlapping of Domains during Appending of case files Reply To: Overlapping of Domains during Appending of case files
aagalvez
Hello, good evening to everyone. Here is an update of case files being appended. I provided some gaps between domains (inlet, rotor, outlet) and came up with this (first picture). My problem now is the creation of mesh interfaces between domains. I tried to manually create mesh interface between the domains but zi am not sure if it is correct. If it is correct, can I proceed already to setup? Thank you very much. Also, I encountered a warning when I tried to write it as one case file in my solution.
