Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Which port should I use, lumped or waveport? › Reply To: Which port should I use, lumped or waveport?
Aymen Mzoughi
Usually wave ports are recommended to use for this case.
You can find a built-in example in HFSS in the menu File > Open Examples > HFSS > Transmission Lines > Coplanar_waveguide.aedt
