Ansys Learning Forum Forums Discuss Simulation LS Dyna Deep-Drawing-Simulation with LS Dyna Reply To: Deep-Drawing-Simulation with LS Dyna
JELO
Hello, thank you for the answer. I reduced ADPFREQ with a smaller number but unfortunatelly the problem is not solved. As material definition I used the Keyword MAT_024_PIECEWISE_LINEAR_PLASTICITY. There I was able to manually enter the plasticity-curve of tensile samples of the sheet. Have you got an other idea? Furthermore I asked myself if the keyword LOAD_SEGMENT_SET defines a pressure which is always normal to the segments? If this is not the case, how can I establish it?
