Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1 › Reply To: Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
MangeshANSYS
Please verify that the installation media is available.
Here is an example command to use
path_to\setup.exe -silent -install_dir “C:\Program Files\ANSYS Inc” -media_dir2 path_to_disk2 -media_dir3 path_to_disk3
can you try manually installong on one test machine using command line only from an elevated command prompt to test if the media is accessible and it can run successfully to completion?
